Altera SGDMA & TSE
I'm not sure you'll get a significant improvement by using polling. It is true that you would spare the time lost by the CPU's handling of the interrupt, but on the other hand if you use the altera HAL do_sync_transfer() function to do polling, then the CPU can't be used to do something else (like sending the data to USB) while it waits for a DMA transfer. Another solution could be to bypass the HAL and use directly the SGDMA registers. When a packet is received, you configure the SGDMA for the next packet, enable it again, then process the received packet, send it through USB, and only then poll for the SGDMA status and wait for a new packet. That way if an Ethernet packet is received while you send the previous one to USB, you won't miss any CPU cycle. But again the gain compared to the solution with interrupt could be marginal.
The most optimal way is to bypass the CPU completely and put everything in hardware.
