19 years agoAltera newbie question
What files are needed to compile into .pof file? If I have .asm file, I would use that to generate .hex file, then what other files would be needed in order to get .pof file? Thanks.
18 years agoI looked in the Quartus 7.1 help file index under-> "files, types in Quartus II software"
There is no mention of a .asm file. What is this .asm file? There is also no mention of .asm in the convert programming files utility. If all you have is a .asm file. I think a .pof file will have a different checksum than the .asm file even if it were compiled with Quartus II Version 5.1 Build 216 03/06/2006 Service Pack 2 SJ Full Version.
