10 years agoaltera monitor problem load
hi, when I try to load the program into hps via altera monitor, it gives me this error:
/usr/bin/bash: up_hps: command not found why? how can I fix it?3 Replies
Yes, and windows won't find it without the path and other environment variables defined in the EDS command shell.
but it is not a command that I wrote, altera uses it in the examples for programs based architecture arm
You need to run that command in the EDS command shell. That shell has the path definition needed to use the command line tools.
