9 years agoALtera MAX10 JTAG Problem
Hello, I made some BLDC and IO expander boards based on Altera MAX10, and i have strange problem that from Quartus at first programming after power was supplied, it does not want to program, but s...
9 years agoHi,
tRAMP time can be found in MAX10 device datasheet which is 10ms max. I am guesing that you were expecting to found this value in "Power Management User Guide". Which device do you use? Single-Supply or Dual-Supply device? Measure your tRAMP time and make sure that all required power supply rails are properly connected.
