14 years agoaltera_installer.external ERROR
Hi! I tried to install Quartus with altera_installer for Linux. I started altera_installer.external.sh with command sh ./altera_installer.external.sh from download folder. Creating directory bi...
14 years agoI'm using Quartus II 11.0 SP1 on Ubuntu 11.10 amd64. My take is that Altera only tested v11 only on Red Hat. I've gotten everything I need to work, but it required a bit of messing around.
I don't remember exactly all the things I did, but I do remember that (1) the installer assumes bash, but doesn't indicate it explicitly on the shebang, (2) there was something about the linux64 and linux directories - Altera Web edition doesn't support 64 Bit, but the apps still try to reference the 64 bit libraries, and (3) I had to use a script to set up the environment properly (PATH and LD_LIBRARY_PATH), especially for Nios II EDS.
