Altera FPGAs in High Performance Computing(HPC) Applications
I am trying to better understand the different methodologies on using Altera FPGAs as a coprocessor in HPC applications.
Believe there there are four known methodologies. Familair with the first three.. 1. Module plugs into processor socket connection-Intel FSB 2. Module plugs into processor socket connection-AMD HyperTransport 3. Module plugged via PCI express interface 4. a. Module plugs into system memory DIMM socket b. Module plugs into a hard drive bay and connects to processor via DIMM socket Trying to get a better feel for Item-4. Wanted to know the pro's and con's of using FPGA on a memory DIMM socket? Does anybody know of any third party companies that use this approach and offer solutions in this space? Thanks!4 Replies
Yes, I did look into Xtremedata products for# 1 and# 2. And for# 3 found GiDEL's solutions suitable www.gidel.com. They have have a tool that can map DSP Builder model based designs to Altera FPGA via PCI express interface(Hardware In the Loop Methodology).
BTW: I am interested in seeing data throughput MB/s for two of Xtremedata's products 1. 2S180 FPGA connected via Intel FSB to a Xeon processor(Xtremedata) FSB interface supports 1066MHz and 64 bits. FPGA I/O connected via FSB might have some speed limitations. What I am looking for the real data throughput that was achieved b/w a 2S180 and a Xeon processor(MB/s)? 2. 2S180 FPGA connected via AMD HyperTransport to an Opteron Processor HyperTransport standard supports 3.2GB/sec(1.6 each way). Again the data I am looking for is the actual throughput between a 2S180 and an Opteron processor. Any thoughts on this? Thanks! - Altera_Forum
For Solutions like# 1 and# 2 try XtremeData. They have some good engineers and are working on developing a more sophisticated toolchain compared to the RTL route.
http://www.xtremedatainc.com/products.html Brian - Altera_Forum
Thank you.
SRC Computers is the company I've heard of for# 4. They were started by Seymour Cray and do a number of different accelerator-type products. Also be sure to investigate the development side, i.e. hardware/software interaction. If you're ready to write HDL, it's usually not a big deal, but a lot of users investigating this area only write C for processors and want to "push a button" to create hardware from their C.
www.srccomp.com
