12 years ago
Altera FPGA with TI A/D EVM
I am totally new to this FPGA world so please ignore my question if they seem basic or stupid. I want to interface 8 channel, 12 bits resolution ADC with at least 50 MSPS A/D FPGA.
I went through Texas Instrument webpage which says:
the hsmc-adc-bridge passive interconnect board enables the output of ti’s lvds output high speed adcs to be directly connected to a standard hsmc interconnect header, a typical input on the latest altera fpga evms.
Can you tell me if Altera DE2-115 Development Board can be interfaced with ADS5281EVM via HSMC-ADC-Bride provided by Texas Instrument ?
Altera DE2 Board: http://www.terasic.com.tw/cgi-bin/page/archive.pl?language=english&categoryno=165&no=502&partno=3
ADS5282EVM: http://www.ti.com/tool/ads5281evm
HSMC-ADC-Bridge: http://www.ti.com/tool/hsmc-adc-bridge
I appreciate your help.
    I re-compiled my existing application for a EP4CE115F896C7 targeting TI ADS5281 12 bit octal ADCs sampling at 50 MHz, and met timing with reasonable slack of about 200 ps setup and hold.
    Thanks Josyb.
    I was afraid if I will end up buying the product not meeting design criteria. Now I am going to order DE2-115 Board and ADS5282 and look forward for the development.
    It will be my first design project. Can you give me some advise to get a head start ?
    Referring to the DE2_115_User_manual_2013, page# 41;
    additionally, when lvds is used as the i/o standard of the hsmc connector, the lvds receivers need to assemble a 100 ohm resistor between two input signals for each pairs.
    I wonder if I have to assemble 100 Ohm resistor myself ? If yes how ? Wouldn't it be difficult to add extra resistor to HSMC ? At least, I didn't find any information if board has 100 Ohm resistor already.
    The schematic shows the 100 ohm resistors as DNI (Do Not Insert) so there will be pads on the PCB to mount these resistors by yourself. I wasn't able to find an assembly drawing of the layout, but I guess they will will be located very near or even under the FPGA.
    --- Quote Start ---
    --- Quote End ---
    Thanks Josyb.
