11 years agoAltera FPGA LED switches OFF after loading the sof file
Hi all, I am trying to load my Altera Arria - II FPGA with the .sof file generated. The loading is successful but the FPGA LEDs switches OFF when it is supposed to turn ON. When I program the F...
11 years ago --- Quote Start --- Your post has far too little detail: What LED is it? one of the ones connected to the FPGA or some other FPGA peripheral? Did you compile it with the same version of quartus (linux/windows and 32/64 bit are all different versions, even if the version number is the same). Does it have full timing specs? Is it on to the same board? --- Quote End --- Well I was able to make the LED blink by loading the NIOS II with the firmware through eclipse compiler. However I was getting error with cygwin because I have a Windows 8.1 OS and after searching for solutions in the Altera forum, I installed an updated version of cygwin and loaded the quartus/cygwin/bin with the new updates bin files. So the current status is I solved this cygwin error but I have one error which is Error : 127 and my .elf file is deleted from the project folder. Could you tell me what do I need to do with it?? I found that it has got to do something with the PATH variable in the environment variables. I tried the solution but it does not work. I found a post in the Altera Forum similar to the error :127 I have got but there is no solution for that post. Can you guys tell me what should I do??
