8 years agoAltera FPGA Fabric Timings - Avaliable?
I've been looking at some Microsemi/Actel FPGA datasheets and they appear to specify timings for different types of gates (AND, XOR, etc). For instance, the Microsemi ProASIC3 nano Flash FPGAs Dat...
8 years ago --- Quote Start --- The technology is fundamentally different. Altera uses luts to model logic. As such, the lut delay is very small compared to the routing. The luts also do not implement a single gate, but anything from one to several. --- Quote End --- We'll sure, but if I want to chain two LE's 4-to-1 LUTs together to form a larger LUT, surely I can bypass one LE's register if I know how long it will take to travel through one LUT to the input of the next LUT, and allow for it by leaving enough time between clocks. --- Quote Start --- For FPGAs, you should have a fully synchronous design, which can then be timing analysed, so timing simulation not necessary. As long as rtl simulation is verified and running analysis passs, your design should work in FPGA. --- Quote End --- But how can timing analysis take place without knowing the parameters?
