ZAhma1
6 years agoALTERA_FP_FUNCTIONS Single Precision Multiplier doesn't seem to support subnormal numbers
I am trying to use a Single Precision Floating Point multiplier as generated by QSys in Quartus Prime 16.1.2. We are using an Arria 10 device so the option I have is to use the ALTERA_FP_FUNCTIONS mo...
- 6 years ago
Yes, I got the problem.
However Altera floating-point IP cores do not support denormal/subnormal number inputs. If the input is a denormal value, the IP core forces the value to zero and treats the value as a zero before going through any operation.
Hence we are seeing output zero.
Anand
ZAhma1
6 years agoHi Anand,
As you may be aware with most FPGA IPs, there is no data valid signal. You just have to wait the suggested number of cycles and hope the output is correct.
I've created a sample project with the IP in question and also added a testbench which will run the problem cases. I'll attach them here.
ZAhma1
6 years agoAnd here is the testbench
