13 years ago
Altera Flex10K, EPF10K10LC84 dev board
hi
i have got an Altera Flex10K, EPF10K10LC84 dev board, which has byteblaster programmer onboard, unfortunately my PC has no LPT port in order to connect the byteblaster so i ordered usb blaster which has been tested with a pretty Altera MaxII board and it works fine. My problem is that the flex10K board has a jtag port but i can't recognize the device if i put my usb blaster cable on it.
Any idea ?
Also is there around a schematic that shows how to build a dev board: i mean the flex10K chip putted on 1000Holes proto board with jtag connector.
I am asking that because i'd like to build the dev board my own with a 50Mhz clock generator onboard.
let me know, regards
    hi
    i've built my own board with the 10pin jtag: today i finished to solder it, and just after putting the usb-jtag on have seen it running =D
    so it works, all is well all ends well
    thank you for your support
    --- Quote Start ---
    --- Quote End ---
    Excellent!
    Cheers,
    Dave
