8 years agoAltera DE2 read input from a weight sensor's HX711 ADC
question: Would it be possible and feasible for a beginner to use Verilog HDL and an Altera DE2 board to read input from a weight sensor's HX711 ADC (see below), and if so: What kind of ...
8 years agoHello Lingyueqing,
The fastest and simplest way to go is use VHDL. If you know Verilog, VHDL is just a matter of syntax. If you want to go the processor way, then you will have to learn how to implement a soft processor on your board and on top of this ARM assembly language. What your chances are depends on your experience and drive. Best regards, Johi.
