18 years agoAlter Beginner
Dear friends I am altera beginner,i want to know that,what is top level entity?,Then one more problem i wrote on vhdl code ,code is this library ieee; use ieee.std_logic_1164.all; entity ...
18 years ago --- Quote Start --- what is top level entity? --- Quote End --- A top level entity is the part of the design that calls other design entities in its design structure. For example, you have entities A, B and C. Further, A uses B and C in its design (and so instantiates them in its design) while B and C are completely independent designs not calling any other entity. Then A is the top-level entity. It is possible that your project may have two designs, say X and Y, which may instantiate some sub-entities (A, B and C), but may not instantiate each other. In that case, two hierarchical structures exist in your project and you must specify which is your top-level entity. Should you choose X, you will not be able to incorporate Y in your project and vice versa. If there is no way X and Y are related to each other, they may form two separate projects. --- Quote Start --- Then one more problem i wrote on vhdl code ,code is this library ieee; use ieee.std_logic_1164.all; entity half_adder is port (x,y,p,q :in bit; z,r :out bit ); end half_adder ; architecture adder of half_adder is component and1 port(a,b :in bit; c:out bit); end component; component xor1 port(e,f:in bit; g:out bit); end component; begin n1:and1 port map(x,y,z); n2:xor1 port map(p,q,r); end adder; it shows the error like that Error: Node instance "n1" instantiates undefined entity "and1" Error: Node instance "n2" instantiates undefined entity "xor1" i don't want what is this,This error cccurs when this module is treated as a top level module.this is one module of the project,if a treat other module as a top level entity there is no error,pls can anybody make me understand what's happening there. regards hareesha --- Quote End --- A very common error for the beginners. Now your program is ok except that it doesn't specify where exactly the compiler should find the entities like and1 and xor1. I suppose you assumed they are available in ieee.std_logic_1164.all package. However what is available in this package is only 'and' or 'xor' (note the absence of index '1' here). Moreover, and and xor are available as functions so instead of using them as entities, you can very well write lines like z <= x and y; and r <= p xor q; in your program.
