10 years ago
all bins on tristate
Im working on a project with MAXV
i got the pcb and soldered the cpld and it accept programming
but all the pins give different voltages 0.9 1.7 2 v
the Quartus 2 give successful build for they synthesis and the fitter
but the bins should output ground not floated with random voltage
is there any option
or something i miss
thankyou
    its my pcb design
    after testing it should be a unconnected bank ground pins so when the input circuitry connect it to ground its float
    but i test all ground pins and all of them are connected well , dont know why, but i will do more testing
    im using 5m240zt100c5
    What is the package you are using? You mention it was hand soldered. Is this on a known-working PCB design, or is it a new one?
    The behavior you indicate would seem to be related to assembly and/or design, and not necessarily an FPGA programming issue per se.
    i tested the io banks , 1 bank works well when assign it to vcc or to gnd
    the other io bank when assigned to vcc works
    but when assigned gnd it floats
