12 years agoAHDL equivalent to Preserve in in Verilog
Hi I am migrating an existing AHL design from MaxPlus to Quartus environment and I noticed that some of the state machine's states/registers were optimized out. I know that in Verilog, Prese...
12 years agoHi
Below is the piece of SM in AHDL base_2 :MACHINE WITH STATES (s0_ base_2, s1_ base_2, s2_ base_2, s3_ base_2); int_ff2.clk = h1; int_ff2.d = zoom_a; base_2.clk = !h1; CASE ( base_2) IS WHEN s0_ base_2 => /int2 = vcc; IF int_ff2.q THEN base_2 = s1_ base_2; ELSE base_2 = s0_ base_2; END IF; WHEN s1_ base_2 => /int2 = gnd; base_2 = s2_ base_2; WHEN s2_ base_2 => /int2 = gnd; base_2 = s3_ base_2; WHEN s3_ base_2 => /int2 = vcc; IF int_ff2.q THEN base_2 = s3_ base_2; ELSE base_2 = s0_ base_2; END IF; END CASE; In Quartus simulation, I could not locate "s2_ base_2" , the warning message was Warning: Can't display state machine states -- register holding state machine bit "s2_base_2" was synthesized away
