admaris
1 year agoAgilex FPGA PRBS Testing Issue
I want to use the Agilex-AGIB027R29A1e1VB-FPGA-REVC-V24.3.1b89-V1.0 project in the examples/qsfpdd_nrz directory to test two groups of Ethernet interfaces for PRBS and count the test results. But afte...
Ash_R_Altera
1 year agoHi,
The provided .sof file is meant for the testing through the BTS GUI. Check the following page:
You can run the PRBS tests from there as well.
I am not sure on the Transceiver toolkit testing with this file as it depends on what is enabled in the IP used to generate the provided .sof.
However, for testing through the toolkit in your custom design, you need to enable some settings. Instructions in the following document page: 7. Debugging F-Tile Transceiver Links
