Agilex F-Tile tx_ready fails to assert
it's good to hear that your tx_ready asserts now. Are you toggling the reset line on the reconfiguration controller as part of post-device configuration. If not, toggle once.
Thank you,
Kshitij Goel
The design I uploaded has the F-Tile reset signal sourced from (init_done || 1v2reset). 1v2reset is connected to GPIO Pin AB53 (FPGA_RESETn on the schematic, page 16) that's routed through the MAX10 to SYS_PB1 on the EVM.
Pressing-and-holding the SYS_PB1 button initiates and maintains the reset. The FGT outputs enter a "hard low" where both signals of the diff pair are down near ground.
Releasing the SYS_PB1 button returns the FGT outputs to a differential-zero - the (p) signals are above ground by about 100mV, and the (n) signals are up around 350mV. It's definitely a distinct change from the in-reset state, but the FGT outputs are stuck at all-zeroes.
