Agilex 7 E-tile Eye diagram viewer failure
Hi Ash,
Thanks for you reply.
I'm sorry but I don't follow here. If you look at the screenshots I sent you I am using the "Agilex E-Tile Transceiver Native PHY Toolkit" in both cases (or as it says in the instances view: "agilex_etile_toolkit_1.0").
When I use the "E-tile Tranceiver PHY IP", the "agilex_etile_toolkit_1.0" is the only option I get.
If I use the "E-tile Hard IP for Ethernet" I also get the option to use "alt_ehipc3_fm_toolkit_1.0" but as you can see in my screenshots, it is the "agilex_etile_toolkit_1.0" that I am using.
I can't see how I can use any other toolkit?
One more thing, I am using Quartus Prime Version 24.2.0 (Build 40 06/27/2024 SC Pro Edition). Let me know if you think that this could be related to this version.
Viktor
