vika
1 year agoAgilex 7 E-tile Eye diagram viewer failure
Hi, I'm using a development board with an Intel Agilex AGFB014R24A2E2V. The FPGA E-tile transceivers are connected to 2 x QSFP28 cages to run 100G Ethernet. We now have the system up and running u...
vika
1 year agoHi Harsh,
Thanks for your reply.
We are using Quartus 24.2 with Linux OS (Ubuntu 22.04).
Are there any particular settings in Transceiver PHY Toolkit that you are referring to?
I've looked at example designs but we are using a reference board from an Intel partner and not a standard reference kit. So I can't use the example design and deploy it on the board as is.
Is there anything else you would like me to try that could give you a hint of what's happening? I was trying to do readouts from the transceiver hard IP but couldn't see anything strange. Is there any registers readout that would help?
Viktor
