vika
1 year agoAgilex 7 E-tile Eye diagram viewer failure
Hi, I'm using a development board with an Intel Agilex AGFB014R24A2E2V. The FPGA E-tile transceivers are connected to 2 x QSFP28 cages to run 100G Ethernet. We now have the system up and running u...
Harshx
1 year agoHi,
Thanks for contacting Intel. I'm assigned to support request.
I'll investigate on this case related to "index 0 out of bounds for length 0" error and get back to you soon once I have any finding.
Meanwhile can I check with you on
- Quartus Version you are using?
- Windows/ Linux?
For your solution:
- It is possible that you may have not implemented the Toolkit settings properly.
- I suggest you check your setup with an example design -> You can also get the eye opening.
Thanks for your patience.
Harsh M
