PAA
1 year agoAgilex 5 Transceiver Tx failing for pll lock
Hi, I am trying to use the Dispaly port IP design example on Agilex 5 device A5ED065BB32AE4SR0 on Arrow AXE5 Eagle development board. However it appears that the Transceiver Tx PLL Lock fails to ...
AR_A_Intel
1 year agoHi
Thanks for your update. Here are some suggestions that may be best for next steps:
· The 1562500 reading may indicate a clocking mismatch. Since you saw changes by adjusting the PMA ref clock, it suggests that the clock path is responsive but may still not match DisplayPort requirements. Confirm the frequency aligns with DisplayPort's expected 1.62, 2.7, 5.4, or 8.1 Gbps configurations.
· Switching to a standard GTS PHY may offer more flexibility for low-level debugging and clock alignment, but it could add complexity if specific DisplayPort optimizations are needed. If the reconfiguration limitations persist, testing with the GTS PHY might help isolate the issue.
