Agilex 5 HPS UART0
Good day,
I would like to connect to UART0 of the HPS. The Pin Connection Guidelines shows the following possible pinouts:
I do not have any of these group pins available. Will it be possible to connect to UART0 via other GPIOs?
Kind regards,
Nicole
Please refer the Agilex-5 device schematic review sheet.
I think you can achieve all your requirement from the HPS IO's.
But, instead of UART0 you can use the UART1 and it will not make difference in accessing.
Also, you can route this UART0 to FPGA fabric as well.
Tiwari
- Jeet14
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
- Jeet14
Tiwari
- sstrell
No, those are the dedicated pin groups available for that peripheral.
- Nicole04
I would like to connect the following peripherals/controllers on the HPS:
- USB0 (USB3 Controller)
- USB1 (USB2 Controller)
- UART0
- HPS JTAG
- eMMC (4-bit)
Can any of the other peripherals be moved so that UART0 is accesible?
Kind regards,
Nicole
- sstrell
The easiest thing to do is to try it out in the Parameter Editor for the HPS in Platform Designer. The tool will let you know if the peripherals you want to use will be available based on the choices you make there.
