Nicole04's avatar
Nicole04
1 year ago
Agilex 5 FPGA E-Series Configuration Flash Memory
Good day,
I would like to use the Active Serial (AS) configuration scheme for configuring the Agilex 5 FPGA. I see the Device Configuration User Guide: Agilex™ 5 FPGAs and SoCs gives a list of compatible flash memory in Table 32. I would like to use a QSPI flash device from ISSI, IS25WP512M-RHLE, this device has a dedicated reset pin. Will I be able to use this device?
Kind regards,
Nicole
  • Hi Nicole04,
    Any Quad SPI flash devices that meet both the following criteria, should be supported.
    • Supports Serial Flash Discoverable Parameter (SFDP) standard
    • Supports dedicated pin reset
    Fakhrul
  • FakhrulA_altera's avatar
    FakhrulA_altera
    Hi ,
    I noticed you marked my earlier comment as the solution. I'm glad your question has been addressed!
    At this point, I’ll transition this thread to community support. If you have any new questions, feel free to open a new thread to receive assistance from Intel experts. Otherwise, the community members will continue to help you here.
    Thank you for your engagement!
    Fakhrul
    FakhrulA_altera
    Hi Nicole04,
    Fakhrul
