12 years agoAfter programing MAX V on Stratix V, fan stop working and no hardware found
Dear All, I am encountering a problem with Stratix V board. I reprogram the MAX V system controller CPLD with some simple design of my own. The fan and LCD stops working after programming. ...
12 years agoIf this kit is the same kind than the ones I have, the Max V handles a part of the USB blaster functionality. So by reflashing it you probably made the on-board USB blaster unusable. Do you have an external USB blaster? Then there should be a JTAG port on the development kit that you can use to reflash the Max V. There should also be some switches to configure to connect the JTAG port to the Max V.
