Affordable İNTEL ALTERA board for communication
Link below listed the available FPGA development kits for all FPGA families.
https://www.intel.com/content/www/us/en/products/details/fpga/find-fpga-boards.html#sort=%40title%20ascending
The Arria V GX FPGA Starter Kit has RJ-45 connector and support Ethernet based communication.
https://www.intel.com/content/www/us/en/products/details/fpga/development-kits/arria/v-gx.html
Application Note AN647 below showcase the Triple-Speed Ethernet example design.
https://www.intel.com/content/www/us/en/docs/programmable/683344/current/single-port-triple-speed-ethernet-and.html
- Abdush4 years ago
Thank you for your replying,
I checked up The Arria GX FPGA starter kit and unfortunately it is not available on any market and also its very expensive, I need only and FPGA like this one
and also I see in this FPGA on Mouser that is saying
Number of Transceivers: 6 Transceiver is the FPGA limits with limited transceivers ports? isn’t all FPGA IO port can be programed to do anything like ethernet or ....etc.
- skbeh4 years ago
Contributor
Based on the link given in my previous note, you can further branch out to search for the development kit that meet your budget.
For stock availablity kindly check with the Distributors in your region.For Cyclone V dev kit, you can refer to below link.
https://www.intel.com/content/www/us/en/products/details/fpga/find-fpga-boards.html#sort=%40title%20ascending&f:facet2=[Cyclone%C2%AE%20V%20FPGAs%20and%20SoC%20FPGAs]&f:@psgcategoriesoffering_en=[Development%20Kits]Regarding the Number of Transceivers, it depends on the Ethernet speed you want to achieve, i.e. 10M, 100M, 1G, 10G...
For a design that using triple-speed ethernet (10M/100M/1G), user can choose to use either the on-chip transceiver channels or LVDS I/Os.
However if the ethernet speed is 10G or above, need to use the high speed dedicated transceiver channels.Triple-Speed Ethernet User Guide for your reference:
https://www.intel.com/content/www/us/en/docs/programmable/683402/21-3-19-5-0/about-this-ip.html- Abdush4 years ago
Also, according to the number of Input and outputs ports of the FPGA chip we have, can we add (implement) any number of ethernet (100base) RJ45 and fibre LC connector to the FPGA ?
What is the way to do that ?
