16 years agoAdvice needed on Cyclone III configuration
I am designing a board with a Cyclone III in EQFP144 package. My I/O voltage is 3.3V and I will be using a serial configuration device. I am wondering about how to wire up the configuration device...
16 years agoI have the same issue. From Chapter 9 of the Cyclone III Device Handbook, Volume I, page 9-10:
"The MSEL pins are powered by VCCINT. The MSEL[3..0] pins have 9-kohm internal pull-down resistors that are always active." This leads me to believe that MSEL[3] is stuck at 0 if it is not available in a package. Are you sure that MSEL[3] is pulled high if it is not available in a package? I'm hoping that this is not the case since I was to use the 3.3V FPP configuration mode (MSEL[3..0] = 1110) on the PQFP-240 package. Is this supported?
