18 years agoaddress decoding in vhdl
hello, I have a soft-core processor and an uart. in order to send the data from output of the processor to the input of uart vhdl module, i'm thinking that i need address decoding to writes the...
18 years ago --- Quote Start --- that means, if i only use the 8 least significants bit, will i have the same output data as before?? --- Quote End --- Yes I believe so, though you must check this out.
