18 years agoaddress decoding in vhdl
hello, I have a soft-core processor and an uart. in order to send the data from output of the processor to the input of uart vhdl module, i'm thinking that i need address decoding to writes the...
18 years ago --- Quote Start --- where should i define my uart address?? in my uart_serial.vhd?? --- Quote End --- You don't need to define uart_address. A uart doesn't need an address, right? The addresses are from the processor. A peripheral to a processor needs an address. So we have double whammy here :). Question: There are address lines coming from a processor but our peripheral/device has no port which looks like an address line. What do we do? Answer: Use some enable signal like chip_select or tx_enable which kicks off the peripheral to work as an equivalent to an address line.
