13 years agoADC0804 interfaced with CPLD
Hello All, I am trying to interface an ADC0804 with a CPLD. The ADC0804 has potentiometerat the input. I have successfully tested the ADC using LEDs at the output, itworked fine. I am now movin...
13 years agoJust for completeness this is the reduce frequency code.
-- Standard libary delarations library ieee; use ieee.std_logic_1164.all; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; -- define input and outputs for the entity --Entity is the device inputs and outputs entity adc is port( --input variable (1-bit) clk_in: in std_logic; --buffer can be input or output clk_out: buffer std_logic; clk: buffer std_logic); end adc; -- internal function of entity architecture behave of adc is --internal variable signal count: integer range 0 to 125000; begin process (count, clk_in,clk_out) begin --signal clk_out: integer; -- Required in order to convert the sinewave to a square wave clk_out <= not clk_in; -- Check for clock to occur and trigger on rising edge if(clk_out'event and clk_out='1') then --increment the count variable by 1 count <=count+1; if (count = 20) then clk <= not clk; -- reset count variable to 1 count <= 1; -- end all the if statements end if; end if; --end the process end process; --end internal function end behave; Jag.
