13 years agoADC0804 interfaced with CPLD
Hello All, I am trying to interface an ADC0804 with a CPLD. The ADC0804 has potentiometerat the input. I have successfully tested the ADC using LEDs at the output, itworked fine. I am now movin...
13 years agoSorry to bother you again Dave.
I can not get me code working, if you can could have a quick look at my code. -- Standard libary delarations library ieee; use ieee.std_logic_1164.all; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; -- define input and outputs for the entity --Entity is the device inputs and outputs entity convert is port( --input variable (1-bit) cs: out std_logic:='1'; rd: out std_logic:='1'; wr: out std_logic:='1'; intr: inout std_logic:='1'; digin: in std_logic_vector(7 downto 0); digout: out std_logic_vector(7 downto 0); flag: out std_logic; --buffer can be input or output conversion: in std_logic); end convert; -- internal function of entity architecture behave of convert is --internal variable signal count2: integer range 0 to 50:=1; --signal count3: integer range 0 to 20:=1; begin process (intr,conversion) begin -- Required in order to convert the sinewave to a square wave -- Check for clock to occur and trigger on rising edge if(conversion'event and conversion='1') then --increment the count variable by 1 count2<=count2+1; if(count2 = 4) then cs<='0'; else if(count2 = 8) then wr<='0'; else if(count2 = 12) then cs<='1'; else if(intr='1') then count2<=count2; end if; if(count2 = 20) then cs<='0'; end if; if(count2 = 30) then rd<='0'; digout<=digin; end if; if(count2 = 40) then rd<='1'; end if; if(count2 = 50) then cs<='1'; count2 <= 1; end if; -- end all the if statements end if; end if; end if; end if; --end if; --end the process end process; --end internal function end behave; There is another part of the code which reduces the 25 MHz clock signal to 625 KHz. The clock out of that component is connected to conversion input. I have connected the 625 clock frequency to pin 4 of the ADC0804 and checked with Oscilliscope. I have output traces showing that code works but I am getting no outputs. Could you please, please give some advice. Jag.
