14 years agoADC Timing Constraints
I feel like I see this question over and over, but can't quite figure out the answer. I've got an 125 MHz clock coming in, from which I generate a 62.5 MHz clock using a TFF, which I then use ...
14 years agoThat's the part that keeps concerning me, is that I'm sort of, kind of, halfway treating this like a source synchronous interface even though it's not quite really one.
I feel like this is a problem that must have a simple, obvious solution, since it must come up all the time. Any time you want to run, for instance, a fast SPI link with the clock coming from a state machine, you're going to have a situation in which you need to close timing around an external device that outputs data in response to a clock coming off a registered FPGA output.
