14 years agoADC Timing Constraints
I feel like I see this question over and over, but can't quite figure out the answer. I've got an 125 MHz clock coming in, from which I generate a 62.5 MHz clock using a TFF, which I then use ...
14 years agoNope, test design doesn't work. I tried the following VHDL file as the entirety of the design logic:
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity temp is
port (
CLK_125_IN : in std_logic;
ADC_DATA : in std_logic_vector(7 downto 0);
ADC_CLK : out std_logic;
LATCHED_DATA : out std_logic_vector(7 downto 0)
end entity temp;
architecture Behavioral of temp is
begin
process (CLK_125_IN)
variable tff : boolean;
begin
if rising_edge(CLK_125_IN) then
if tff then
LATCHED_DATA <= ADC_DATA;
ADC_CLK <= '1';
else
ADC_CLK <= '0';
end if;
tff := not tff;
end if;
end process;
end architecture Behavioral;
And the following constraints file:
set_time_format -unit ns -decimal_places 3
create_clock -name {CLK125} -period 8.000
create_generated_clock -name {tff_clk} -source -divide_by 2
create_generated_clock -name {adc_clk} -source
set_input_delay -add_delay -rise -max -clock 12.000 ]
set_input_delay -add_delay -rise -min -clock 3.900 ]
set_multicycle_path -setup -end -from -to 2
set_multicycle_path -hold -end -from -to 1
Still, no path to adc_clk. Same thing if I strike the tff_clk and just derive adc_clk straight from CLK_125_IN.
