10 years agoActive serial configuration problem
Hi, This probably a very lame question, but I'm sort of stuck. I have Cyclone II mini board, all works fine and I want to store my configuration in configurator. What I did is: 1. In D...
10 years ago --- Quote Start --- Try erasing the EPCS before programming. --- Quote End --- I finally found what it was. There is another configuratin option - generate compressed bitstreams, which by default it enabled, but should be switched off in order to work.. Thanks.
- Facundo_Olmedo5 years ago
That solution doesn't worked for me. I'm still having the same problem.
