pgigliotti_uasc
3 years agoAccessing user data in configuration flash
I have two designs (Arria V and Cyclone V) both using EPCQ256 flash memories for configuration of the FPGAs. After configuration, I need to use a home grown SPI controller to access this memory (bot...
- 2 years ago
Here is the solution - Instantiate the "Intel® FPGA Serial Flash Loader IP Core" and hook up a QSPI controller to this core.
Here is a link to YOUR document - 1.9. Intel® FPGA Serial Flash Loader IP Core Signals
FakhrulA_altera
3 years agoHi pgigliotti,
I wish to follow up with you about this case. Do you have any further questions on this matter? Otherwise, this thread will be idling and marked as inactive, thus it will be transitioned to community support because there is no update received from you in a while.
Fakhrul
