Accessing user data in configuration flash
- 2 years ago
Here is the solution - Instantiate the "Intel® FPGA Serial Flash Loader IP Core" and hook up a QSPI controller to this core.
Here is a link to YOUR document - 1.9. Intel® FPGA Serial Flash Loader IP Core Signals
all you need to do is to declare all involves AS pins as IO in user mode. I'm mostly using altasm_parallel to access flash memory.
- pgigliotti_uasc3 years ago
It sounds easy enough, but is there anything I need to do to assign in user mode, besides just using them in the design and constraining them to the AS pins?
- FvM3 years ago
Instantiate the flash controller of your choice and try to compile.- pgigliotti_uasc3 years ago
When we try to assign the pins in the Pin Planner, it gives an error message that the pins are “not assignable”. When we do it manually in the Assignment Editor window and in the QSF file, but when we try to compile after that, it fails on the Fitter saying it “cannot place the components due to conflicts with existing constraints”.
We searched the issue online, and there was an Intel support page saying the pins not being assignable in user mode is an issue with Quartus, and to add two lines to the QSF file. we added those lines, but it gave usthe same issue when trying to compile. (Here’s the link to that page: How do I assign dual-purpose pins to be a user I/O after... (intel.com))
If there’s anything else you think we should try, let us know.
