14 years agoAccessing JTAG_UART from Matlab
Hi, I am trying to build an interface between an FPGA (Quartus-II 64-bit v11.1sp2) and Matlab (R2011b) using the JTAG-UART. Unfortunately the documentation provided by Altera for their DLLs is ...
14 years agoHi JoBird,
I just got done putting together a tutorial on my blog about how to use the Virtual JTAG MegaFunction, with a Tcl TCP/IP Server (which runs in the quartus_stp.exe). From there you can talk to the FPGA's design using just about any programming language that supports TCP/IP connections. Might be a possible option for you: http://idle-logic.com/2012/04/15/talking-to-the-de0-nano-using-the-virtual-jtag-interface/ After making the tutorial, I found that Dave wrote a more rigorous tutorial on this sort of solution here: http://www.alterawiki.com/wiki/using_the_usb-blaster_as_an_sopc/qsys_avalon-mm_master_tutorial It would be nice to find a way to get rid of the Tcl middle layer, but I assumed I would have the same problems as you of trying to reverse engineer the Altera DLL's. Maybe someone else knows the trick... Regards, Chris
