10 years agoAccess HPS SDRAM from NIOS II
i am new to SOC devices, and i am using QII 15.0 and NIOS II ESD 15.0. Now i am trying to access HPS SDRAM from a NIOS II programm. The HPS is running Linux, and the FPGA has a NIOS II Processor without OS. I added a FPGA to SDRAM Interface (f2h_sdram0, Avalon MM Bidirectional, 32) to the Cyclone V hps and i connected it to a address span extender (Enable slave control port = false). In my NIOS II system.h i have the following entry:# define ALT_MODULE_CLASS_hps_0_bridges hps_bridge_avalon# define HPS_0_BRIDGES_BASE 0x1400000# define HPS_0_BRIDGES_IRQ -1# define HPS_0_BRIDGES_IRQ_INTERRUPT_CONTROLLER_ID -1# define HPS_0_BRIDGES_NAME "/dev/hps_0_bridges"# define HPS_0_BRIDGES_SPAN 4194304# define HPS_0_BRIDGES_TYPE "hps_bridge_avalon"
Now i am tryingt to read from the HPS SDRAM using: data = IORD(HPS_0_BRIDGES_BASE, 1) When NIOS II executes the instruction it gets stalled. A read to other addresses outside the address span extenders range works. Do i have to use any other function to read from HPS sdram / address span extender? Do i have to tell the HPS that there is another device trying to access the memory? Any other ideas, why NIOS II gets stalled when reading from addresses inside the HPS / address span extenders space? Thanks, Patrick5 Replies
thank you for your fast responses! I think you are right, i never build the preloader / uboot, because the Demoboard i am using came shipped with a example (Ubuntu Linux) which i adapted to my needs (FPGA-Fabric only). I did not know, that the preloader affects the bridges to the FPGA. I will try to build the preloader and uboot using bsp-editor. I will post my results here! Thanks again, Patrick - Altera_Forum
agree !!!!! you are right!
normally the bridges get enabled in uboot-stage, but the handoff for the bridges gets passed from preloader, but if you know the handoff, you could use the old preloader and set the handoff manually...
That's right, not sure if you enable this in preloader or uboot. By the way, are you using bsp-editor or custom yocto build ?.
have you build a new Preloader (SPL) after building the QSYS-System and have you enabled the bridges in uboot-stage? What is your fpga2sdram_handoff in uboot?
