About writing JBC files using altera-stapl
- 2 months agoGood question — let me work through the failure modes systematically based on what's documented for MAX 10 JBC/JAM programming.
The core issue: POF-based JBC vs. SOF-based JBC for MAX 10
The fact that your SOF-derived JBC succeeds but your POF-derived JBC fails is a very important clue. For MAX 10, programming the internal flash (CFM) via a POF uses the real-time ISP (in-system programming) flow, which has specific requirements that JTAG configuration from a SOF does not.
Most likely root cause: DO_REAL_TIME_ISP not set in the generated JBC
There is a documented issue where JAM/JBC files generated for MAX 10 devices do not contain the DO_REAL_TIME_ISP option. This problem is specifically seen when other FPGA devices are in a JTAG chain with MAX 10, and is due to incorrect formatting in Quartus Prime Software when converting the programming file to JBC or JAM.
When the real-time ISP option is missing or incorrectly set in the JBC, the Jam player can fail with an "Unrecognized device" / Exit code = 6 error — which matches exactly what you're seeing.
There is also a separate but related issue: when a MAX 10 FPGA is blank (new device, or UFM and CFM erased), the JAM player cannot program it successfully and returns "Exit code=10, Device programming failure". This is because the real-time ISP feature is turned on when the device is not in user mode. To fix this, use the JAM player command to disable the real-time ISP feature and program again. If your device is in a partially erased state, this could also contribute.
How to correctly generate the JBC for POF-based (flash) programming
The key step that is easy to miss: you must select "Enable real-time ISP to allow background programming" prior to creating the JAM file to enable ISP clamp for the JAM STAPL flow.
Specifically: in Quartus Prime 17.1 and later, you need to check the option "Enable real-time ISP to allow background programming when available" in the Programmer window before generating the JAM file — this is what produces a JAM/JBC that contains the DO_REAL_TIME_ISP option.
Then, when invoking the player: for real-time ISP with the JBC and Jam STAPL Byte-Code Player, the command is:
jbi_22 -aprogram -ddo_real_time_isp=1 file_name.jbc— the-ddo_real_time_isp=1flag must be passed explicitly.With
quartus_jlithe equivalent is:quartus_jli -aPROGRAM --enable=DO_REAL_TIME_ISP <file>.jbcRegarding Quartus version compatibility
JAM/JBC files generated in Quartus Prime 17.0 do not contain the DO_REAL_TIME_ISP option due to a known bug. The workaround is to use JAM/JBC files generated in version 16.1; the issue was fixed in version 17.1. Since you are on 25.1, this specific 17.0 bug is not your problem — but it confirms that the DO_REAL_TIME_ISP flag in the generated file is version-sensitive and must be verified.
As for altera-stapl / jamplayer compatibility: the Jam STAPL player is a C program that parses the JAM/JBC file and drives the JTAG chain. You can download the latest version of the Jam STAPL and Jam STAPL Byte-Code Player from the Altera website. If you are using an old build of altera-stapl, it may not correctly handle the DO_REAL_TIME_ISP variable or the MAX 10-specific real-time ISP instruction sequence. I'd recommend verifying against the latest player source from Altera, or switching to
quartus_jlifor validation.Recommended debug steps
- Open the generated .jam file in a text editor and confirm it contains a
DO_REAL_TIME_ISPvariable/action. If it does not, regenerate with "Enable real-time ISP to allow background programming" checked in the Programmer before doing File → Create JAM, JBC, SVF or ISC File. - As a workaround for the multi-device JTAG chain formatting issue: check "Enable real-time ISP to allow background programming when available" (below the Hardware Setup button), then execute "Create JAM, JBC, SVF or ISC File" to regenerate.
- When calling the player, explicitly pass
-ddo_real_time_isp=1(or the equivalent in altera-stapl's API). - If the device may be blank/erased, disable real-time ISP for the initial programming pass.
- Validate the full flow using
quartus_jlifirst to isolate whether the issue is in the JBC file itself or in altera-stapl's execution of it.
The "No SLD node / Unrecognized device" sequence strongly points to the player failing to enter real-time ISP mode correctly before attempting flash programming — fixing the DO_REAL_TIME_ISP flag in generation and invocation should resolve it.
Sources: MAX 10 · Config/RSU, MAX 10 · Config/RSU, MAX 10 · Config/RSU, MAX 10 · Config/RSU, MAX 10 · Config/RSU, MAX 10 · Config/RSU, MAX 10 · Config/RSU, MAX 10 · Config/RSU, MAX 10 · Config/RSU, MAX 10 · General, MAX 10 · Config/RSU
Do you have further question?
Thank you for providing a thorough analysis of the cause and suggesting improvements.
As you pointed out, the cause was that the "Enable real-time ISP to allow background programming" option was not checked before creating the JAM file.
After making this correction, I used the JBC file generated from the newly created JAM file and successfully programmed from the SoM to the MAX10.
I am truly grateful.
Thank you very much.
- Farabi_Altera2 months ago
thank you! I am closing this thread now.
