17 years agoAbout Transceiver???
If there was a serial digital data stream whose speed was 1Gbps. Can I recovery these datas by transceiver? If I can, how to realize it? And another question, is the transceiver valid for recoverying...
13 years agoHi all
I have a similar question I need to design a CDR working at 160 Mbps, +/- 1% the input frame is NRZ biphase mark: 00110101101001.. ( max 2 consecutive "0" or "1" ) I can do it by using a ADN1814 : http://www.analog.com/en/clock-and-timing/clock-and-data-recoveryretiming/adn2814/products/product.html but, is it possible to do the same by using the CRD inside transeiver of the ARRIA ? Thanks in advance for your help JJ
