17 years agoabout the storage problem on Stratix II
Hi everyone, As I am new to the FPGA board... The problem that I am facing is I need to store the result to the compact flash card, but I don't know how to achieve the task. The situation ...
17 years agoAvailable CF card examples are using NIOS II enbedded processor to control the storage interface, I think. You may want to design a native low level interface (using True IDE mode) based on the card specification available from card vendors.
You should also check, if the sustained write speed achievable with CF cards is sufficient for your application.
