14 years agoabout the 8B/10B encoder altgx
hello, according with the manual, in double width mode, the 8B/10B encoder starts the LSByte with a negative disparity (RD-)and the MSByte with a positive disparity (RD+) after reset. In my si...
14 years agoI don't see a problem.
It's just how 8B/10B works: RD doesn't always toggle from byte to byte. Consider a single encoder: a) Most cases are encoded such that RD toggles after each byte. b) However, there are some cases which are encoded in such a way that the RD stays the same. For the double encoder scheme, which are used for every other byte, this becomes: a) Most cases, each encoder's RD stays quiet. b) In some cases, both encoders toggle their RD.
