MartinMaa
2 years agoABOUT MAX10 FPGA OVERSHOOT CIRCUIT
Hello, I am writing to you regarding the overshoot protection circuit (circled in red in the image). These circuits are used for one-time use only, and I also have space constraints on my PCB...
- 2 years ago
It is feasible to have the marked circuit on the separate board, provided the GND are connected and the VCCIO is sourced from the main board.
FvM
2 years agoHi, using protection circuits for external signals driving FPGA pins directly is generally a good idea. If you actually observe overshoot potentially degrading or even damaging FPGA IOs depends drive strength and rise time of connected circuit as well as cable length. An USB Blaster with original cable e.g. doesn't necessarily need clamping diodes. There's still a risk of ESD damage if not using appropriate protection means, in so far your separate board doesn't solve all possible problem.
I think, it's a matter of use case, in which environment programming will be performed.
