allen18
3 years agoAbout JESD204b pin constrains
Hi: I am using the Stratix 10 H-tile series FPGA, and for the JESD204B IP core, I found that in the example design, the voltage standard for rx data and refclk are constrained to CML. However,...
- 2 years ago
Hi Allen,
Good day.
Regarding to your question, yes LVDS and LVPECL will be better than HCSL.
Hope this answers your question.
Thank you.
ZH_Intel
ZH_Intel
2 years agoHi Allen,
Good day.
Apologize for the delayed response.
Based on the discussion with internal team, you may constrain the data as CML and constrain the clock as HCSL but it is not recommended by Intel as it will impact timing.
By doing so will have risk.
For JESD204 IP, it is advisable to connect direct Tx to Rx.
Thank you.
ZH_Intel
allen18
2 years agoThank you for your reply.
If I constrain the clock as lvds or lvpecl will be better than hcsl ?
