19 years agoAbout cyclone II diferential LVDS pins
I want to ask about cyclone II diferential pins with interface like LVDS, can these diferntial pins be used as Comparators ??? and how acurate they are? and will they realy work as comparators ??...
19 years agohere is picture of first searching algorithm.(it is realy simple:
Process(clock)
begin
if rising_edge(clock) then
if reset ='1' then DAC_reg <= "01000"; S_loop <= starts;
else S_loop <= starts;
case S_loop is
when Starts => if COMP ='0' then S_loop <= Minus;
else S_loop <= Plus; end if;
when Plus => if (DAC_reg = ALL_ones) then S_loop <= Starts ;
else DAC_reg <= DAC_reg + 1; S_Loop <= Starts;
end if;
when Minus =>
if DAC_reg ="00000" then S_loop <= Starts ;
else DAC_reg <= DAC_reg - 1; S_Loop <= Starts;
end if;
when Others => S_loop <= Starts;
End case;
end if;
end if;
end process;
(I used state machine + aditional code to not owecome DAC max, min values like 00000, 11111) blue line is analog signal and red line is DAC converter output that is connected to LVDS pins negative side and positive pins input is analog signal(blue line). https://www.alteraforum.com/forum/attachment.php?attachmentid=116 as you can see it is possible to make adc out of fpga's LVDS pins but this resolution is pour but I have idea how to make this resolution higher and how to get more accurate results using more complex searching algorithm.
