SHUN_K
2 years agoAbout containing chemical substances
Please let us know if your product 10M40DAF484 contains Dechlorane Plus, UV-328, and Methoxychlor.
NazrulNaim_Intel
2 years agoHello,
Sorry for the delay. For more information regarding your request. It can be accessed through the link below.
Link : https://cdrdv2.intel.com/v1/dl/getContent/694499?fileName=10M08DAF484C8G_20191128003306_v1.xml
Below is the step how to open XML file in Excel
- Open a new blank Excel file
- Click on Developer tab, then click Import
- Select the xml file you want to import, then click Import
- Click "OK" on pop-op information, and also "OK" on where to Import data
- The table will then be generated, and you will see a lot of "blank" cells due to the long text of the "legalDef" column AK.
- I recommend to delete column AK so that the other columns will display better:
Hope that helps you resolve the issue.
Nazrul Naim
SHUN_K
2 years agoHello,
Thank you for providing information.
Thanks to this I may be able to solve the problem.
I’m looking forward to doing business with you.
SHUN_K
