18 years agoAbout "alt_flash_open_dev" and CFI table
hi, when i use function "alt_flash_open_dev" to open a CFI, i can't get the correct base address which i set in SOPC. and i'm sure i have already include the relative head files.I don't know why.And ...
18 years ago --- Quote Start --- hi, I have the same problem. If you solved the problem, I want to know the way of solution. --- Quote End --- in version7.0, it was automatically solved for you. And I got stuck in other versions.
