A10 SoC: issue with .sopcinfo file while generating dts file
Can you send me the .qsys file for investigation?
Which Quartus version are you using?
Thank you
sure...i am using Quartus prime 18.0,
regarding the attached sources...
In the design i have added PCIe HIP too,..I am concerned only about the altera_emif as it is not recognized while running sopc2dts command in soc eds command shell.
In the *.dts file i could see the following script for altera_emif.
fpga_emif: unknown@0x000000000 {
compatible = "unknown,unknown-18.0";
reg = <0x00000000 0x00000000 0x10000000>;
}; //end unknown@0x000000000 (fpga_emif)
The background is , i want the HPS to communicate to the altera_emif so i connected the h2f_axi_master port of HPS to the ctrl_amm_0 port of EMIF.
- Matt16 years ago
Hi FJumaah,
any updates regarding the above case!!
I am a bit confused after reading the below info!!
i got an info from intel website with the title "Spurious Error Messages from sopc2dts" and its is with reference to Arria V and cyclone V devices.
Description:
When you are generating the device-tree source file (.dts) for an SoC HPS hardware design, you might see a large number of spurious error messages. The following list shows some of messages produced by sopc2dts:
sopc2dts --input soc_system.sopcinfo --output soc_system.dts --board
soc_system_board_info.xml
Failed to find h2f_lw_reset
Failed to find f2h_reset
Component hps_0 of class altera_hps is unknown
Workaround/Fix:
No workaround is necessary. You can safely disregard the warning messages and proceed to compile your device tree sources normally.
why it so?is it valid for A10 soc?
Source:
https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/solutions/fb127751.html
regards
matt
