JET60200
Contributor
6 years agoA10 CPRI example design
Hi, we have a A10GX board which needs to support CPRI 6.0 protocol. I wonder is there a CPRI example design. Appreciate help. Thanks
JET60200
Contributor
6 years agoHi @cheepinc_Intel ,
For other IPs, (such as 10GE MAC, etc), we can easily generate an IP example in “Parameter Editor”, we can open the example in Quartus Pro, compile it, and try execute on HW board.
But for CPRI IP, it seems there's only a testbench to be generated? we cann't open and compile it on Quartus, and execute it on hardware. Is that true ?
I just want to have a cpri example to verify our customer board Pin Assignment correct ot not . Thanks
CheepinC_altera
6 years agoHi,
Yes you are right. The IP can only generate test bench. For HW design example, as I search into the Design Store, I come across one CPRI example design as following:
https://fpgacloud.intel.com/devstore/platform/16.0.0/Standard/cpri_98_comp_iqmap_a10/
As a workaround, you can try to look into this design to see if it will be helpful. Note that as I look through the user guide, some of the reference are pointed to alterawiki which was no longer accessible. Also, the design seems to be for Q16.0. Thus, you might need to try out to see if this design will work for you.
Thank you.
Chee Pin
