18 years agoA very basic newbie question
Hi All I have a very basic question. I've recently started learning about CPLD and VHDL. My VHDL code usually compiles and simulates fine, but when I put it in an actual CPLD it behaves really...
18 years ago --- Quote Start --- Thanks for all your answers, very informative. I have improved my code a lot. All my problems went away (even using the original code) when I changed the policy for unused pins from "As output driving an unspecified signal" to "As input tri-stated ". Anyone knows why? --- Quote End --- The default setting of Quartus for unused pins ( Output driving ..) is dangerous in case of FPGA boards with external components. It is very likely that unused FPGA outputs will drive against ouputs of other components.
