16 years agoa verilog syntax issue that i can't figure out
i have a verilog design of an sdcontroller which i obtained from opencores and which iam trying to simulate. well its a certified design but its giving one peculiar error. one of the design files whe...
16 years ago --- Quote Start --- This code is missing the "module" statement. in my opinion the initial lines are missing. no i dont think it has to be a module necessarily. iam new to verilog so iam not sure but ive seen similar code elsewhere. i guess it's some sort of portmapping. in any case this is a certified design. could there be something wrong with the compiler modelsim or some compile option that iam missing. ive already designated it as a system verilog file. see the -sv switch in the compile command above.:) ---------------------------------------------------------------------------------------------------------------------------------------------------- What is ther in sd_defines.v ? --- Quote End --- `define BIG_ENDIAN `define TIME_OUT_TIME 255 //OBS komihåg Master SEL to 1111 vid port dek //`define SIM `define SYN `define ACTEL `ifdef SYN `define RESET_CLK_DIV 2 `define MEM_OFFSET 4 `endif `ifdef SIM `define RESET_CLK_DIV 0 `define MEM_OFFSET 1 `endif //SD-Clock Defines --------- //Use bus clock or a seperate external clock? `define SD_CLK_BUS_CLK //`define SD_CLK_EXT // Use internal clock divider? `define SD_CLK_STATIC //`define SD_CLK_DYNAMIC //SD DATA-transfer defines--- `define BLOCK_SIZE 512 `define SD_BUS_WIDTH_4 `define SD_BUS_W 4 //at 512 bytes per block, equal 1024 4 bytes writings with a bus width of 4, add 2 for startbit and Z bit. //Add 18 for crc, endbit and z. `define BIT_BLOCK 1044 `define CRC_OFF 19 `define BIT_BLOCK_REC 1024 `define BIT_CRC_CYCLE 16 //FIFO defines---------------
